Posted: 2020-07-03 09:22 AM . Last Modified: 2024-04-08 03:33 AM
Hi
I was looking at using AP9335TH Temp / Humidity sensor with NBPD0150 Rack Pod connected to the Netbotz rack monitor 200.
I want to use this purely to monitor conditions over time. How many data points (historically) can it log and what way would it be displayed or downloaded from the basic web set-up that comes with the Netbotz rack monitor 200.
If anyone has any links or info on the basic web page that would be a help also.
Many thanks
David
(CID:110010211)
Dear David,
As far as I know, the data logs points storage appliance depend upon the interval which we select on the Netbotz 200 Interface and also depends upon the number of Sensors Pods connected. The Netbotz 200 Web Interface also lets the user know on how many days data can be stored on the Appliance depending upon the settings under Logs--Interval
For example:
Please refer the below K-base document to download the data logs through FTP Method. NBRK0200 uses NMC1 card.
http://www.schneider-electric.co.in/en/faqs/FA156131/
You can refer testdrive.apc.com website to view the NBRK0200 Web Interface demo.
http://testdrive.apc.com/enviro.htm#emu
User name and Password: apc
I also would suggest you to consider DCE software for more better performance of data analysis. With DCE, you can store all the sensors data for a longer duration, and it will be useful for you to analyze the trend of the values by DCE-Reports option. The following is taken from DCE web interface for a Netbotz 200's temperature sensor.
I hope this helps.
Bala
(CID:110010248)
Dear David,
For example:
I hope this helps.
Bala
(CID:110010248)
Hey Bala.
Thats great info. Thanks for taking the time to respond.
(CID:110010285)
Posted: 2020-07-03 09:23 AM . Last Modified: 2024-04-08 03:33 AM
You are welcome David!! Wish you happy new year in advance and happy Christmas!!!
(CID:110010409)
Hi.
Is the APC NetBotz product line obsolete, as i am seeing on the web netbotz200 is obsolete.
If it's just the 200 unit what is its replacement model ? Is the 250 compatible with the 150 sensor pod and temp/humidity sensors AP9335TH or is the next compatible model the 450?
Again thanks for the info. Just got through it all.
David
(CID:110010749)
Posted: 2020-07-03 09:23 AM . Last Modified: 2023-10-22 03:24 AM
