DCE Alert For Multiple Sensors
  • DCE Alert For Multiple Sensors
126
65
Posted: ‎2020-07-03 09:22 AM . Last Modified: ‎2024-04-08 03:34 AM
944
Is there a way to create an alarm threshold for two sensors on two different devices, without creating a total virtual sensor.
For example Device A has a sensor point called Total Amps A and Device B has a senor called Total Amps B.  Can I setup ap an alarm to trigger if the combined value of Total Amps A and Total Amps B breaches 10?
At the moment I can only seem create a total virtual senor for both then set an alarm on this virtual sensor.  Whilst this is relatively straight forward it can be time consuming when large numbers of devices are present.
(CID:110010187)
Dear James,
I am sorry to disappoint you. As far as I know, the feature which you are looking for is not not currently available in DCE. The only way to combine the sensors values is to use the Virtual Sensor option, and set the threshold for the same. If possible, please raise your query in feature request so that team can look at your request.
Feature requests
I also let other community experts to suggest on your query if there is any other way around.
Bala
(CID:110010258)
Dear James,
Feature requests
Bala
(CID:110010258)
I also faced similar need.
Can someone please answer, how can I create alarm from 2 state sensors?
In my case alarm should be triggered when both state sensors are "inactive".
Thanks in advance,
Janis.
(CID:134689370)
Posted: ‎2020-07-03 09:22 AM . Last Modified: ‎2023-10-22 01:14 AM
