Posted: 2020-07-03 12:47 AM . Last Modified: 2024-04-09 12:49 AM
Hi all ,
I used Netbotz 570 to monitor Uniflair SDCV0400A by SNMP , it can connect but had no data ,
pls see the screenshot , does our netbotz not support this model ? Thanks .
Best Regards
(CID:105467918)
Billy,
You'll need the DDF file to get sensors data to be shown. Now the tricky part is, this is Netbotz, I am not sure multivendor still creates/updates DDF file for Netbotz.
In the mean time, you can manually add a few OIDs under Netbotz's supplemental OIDs to get some sensor reading data. Get a copy of the Uniflair/pcoweb's MIB file from your local cooling expert.
Also, do take note on the minimum SNMP polling time for Netbotz is only 5 minutes.
Hope this helped.
Chris
(CID:105467925)
Billy,
Hope this helped.
Chris
(CID:105467925)
Hi Christopherus , Thank you for kindly advise , I also concern if the DDF can support Netbotz , Anyway ,I'll check the multi support ,thank you . Best Regards
(CID:105467926)
Hi Chris, Chu, No, Multivendor is not creating DDFs for NetBotz at this time and supplemental OIDs are the only alternative without an existing DDF. Please note we will only accurately work with numeric sensors and not text when using this option. You may want to look into the free 5 node DCE VM server. Steve
(CID:105467982)
Posted: 2020-07-03 12:47 AM . Last Modified: 2023-10-31 11:25 PM
