Posted: 2020-07-03 12:46 AM . Last Modified: 2024-04-09 12:49 AM
(CID:105467898)
Hi Sunny,
Go to below web links may it will help you.
http://www.powerlogic.com/literature/ION7550_ION7650_Installation_Guide.pdf
http://www.powerlogic.com/literature/ION%20Meter%20as%20an%20Ethernet%20Gateway.pdf
http://www.powerlogic.com/literature/ION_Devices_Modbus_Register_Map.pdf
BR,
Rana Ajmal
(CID:105467900)
Posted: 2020-07-03 12:47 AM . Last Modified: 2024-04-09 12:49 AM
Hi Sunny,
Rana provided some excellent documentation on installing the meter. If all you're looking to do is to add it to StruxureWare though, you need the correct DDF in StruxureWare and then simply need to add it as a Modbus or SNMP device. I'm assuming Modbus.
You will need to add it via Modbus over tcp so if the unit does not have that option natively, you'll need to add a try to top gateway. If you don't have the correct DDF, you'll want to contact the following email address:
Steve
(CID:105467905)
Posted: 2020-07-03 12:47 AM . Last Modified: 2023-10-31 11:01 PM
