DCE 7.3.1 vulnerability to CVE-1999-0524
  • DCE 7.3.1 vulnerability to CVE-1999-0524
126
65
Posted: ‎2020-07-03 12:47 AM . Last Modified: ‎2024-04-09 12:49 AM
1958
We have picked up that DCE v7.3.1 is vulnerable to CVE-1999-0524. Will there be a patch for this or will be sorted in the next release?
(CID:105467933)
Posted: ‎2020-07-03 12:48 AM . Last Modified: ‎2024-04-09 12:49 AM
1958
Hi Kevin,
From what engineering has mentioned to me, this CVE in itself does not allow any damage by itselc however as the CVE notes:
ICMP information such as (1) netmask and (2) timestamp is allowed from arbitrary hosts.
If the customer needs to have this information blocked, they can use their router or firewalls to block pings and ping responses. Here was the reply I received:
This CVE pertains to general characteristics of having ICMP enabled on your network or having devices support/respond to ICMP requests. The customer should use their firewall to block these accordingly or they could disable ICMP completely.
Steve
(CID:105467989)
Replies 5
1958
Hi Kevin,
I looked at this vulnerability from 1999 and it is apparently a very low severity.
https://web.nvd.nist.gov/view/vuln/detail?vulnId=CVE-1999-0524
Impact
CVSS Severity (version 2.0):
CVSS v2 Base Score: 0.0 LOW
This vulnerability existed before APC even purchased NetBotz so I'm assuming this was deemed too low to worry about. Still, I will double check with engineering to see if this is something that they can put on their radar but due to the age and severity, I do not think they have been looking at ti nor will they be looking at it going forward.
Just to be sure, what did they use to scan DCE? Do you have the tool's output?
Steve
(CID:105467984)
Thank you Steven.
(CID:105467994)
1959
Hi Kevin,
Steve
(CID:105467989)
Thank you Steven. Much appreciated
(CID:105467995)
Posted: ‎2020-07-03 12:48 AM . Last Modified: ‎2023-10-31 10:25 PM
