Netbotz NBRK0201 connect to NBES0301 (spot fluid) via NBPD0150
  • EcoStruxure IT forum
  • Netbotz NBRK0201 connect to NBES0301 (spot fluid) via NBPD0150
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 10:44 AM . Last Modified: ‎2024-04-10 12:46 AM
537
Dear All ,
just want to ask about is there anyone ever tried to connect  spot fluid sensor NBES0301 via NBPD0150 and join it with NBRK0201, is it work?
Thanks ,
samuel
Avnet - Indonesia
(CID:94601297)
  • Data Center Operation
  • NetBotz
Replies 4
NO. Netbotz 201 supports only temperature, humidity, dry contact and door switch sensors
Fluid senson can work only with NetBotz 35x/45x/451/551/570
(CID:94601300)
537
Hi Samuel,
The spot fluid sensor is not supported on the NBRK0201 via NBPD0150. The devices supported by the 150 pod work only when connected to an appliance that supports them.
You would need a Netbotz 3xx, 4xx or 5xx Netbotz appliance to support the spot fluid sensor.
Breda
(CID:94601301)
dear Breda , thanks for your information , we'll confirm this issue to our customer. best regards, samuel
(CID:94601310)
Posted: ‎2020-07-02 10:45 AM . Last Modified: ‎2023-10-31 11:26 PM
