How to delete upgarde file from webmin 1.6
  • How to delete upgarde file from webmin 1.6
129
72
Posted: ‎2020-07-02 10:45 AM . Last Modified: ‎2024-04-10 12:46 AM
1055
    I want to delete upgrade file from webmin how can I do. please see the attached screenshot.
(CID:94601309)
  • Data Center Operation
1055
I believe deleting file(s) via Webmin is not supported - I would suggest the following options:
1. either use a file transfer tool (WinSCP or similar) to transfer or delete file(s)
2. or ssh log in to the server, and then go to the location and delete the file, ex:
cd /data/upgrade
sudo rm StruxureWareDataCenterOperation-Upgrade-7.4.5.tgz
(CID:94601321)
1056
cd /data/upgrade
(CID:94601321)
Thanks Jef
(CID:94601327)
Posted: ‎2020-07-02 10:46 AM . Last Modified: ‎2023-10-31 11:05 PM
