Alarm Configuration filtering - DCE
  • Alarm Configuration filtering - DCE
129
72
Posted: ‎2020-07-02 10:44 AM . Last Modified: ‎2024-04-10 12:47 AM
827
I am trying to adjust the alarm configuration for all Environmental monitors however I can not seem to sort just the Environmental monitors.
In the "Alarm Configuration" tab, I searched for "Environmental Monitor" which showed me just the Environmental monitors, however in the "Threshold Alarm Configuration" Tab under "Maximum Value - Temperature" it still shows me InRow probes i.e. "Maximum Value - Group Maximum Rack Inlet Temperature".
So my question is, how can I just change the Severity of the Environmental temp probes and not InRow points.
I am running DCE 7.2.0
J
(CID:94601280)
827
Hi John!
You need to filter output in Treshold Alarm Configaration tab too, like this:
I have no Environmental monitoring units in our lab setup, so there is example with UPS and InRow unit temperatures. Hope it help you.
(CID:94601286)
828
Hi John!
(CID:94601286)
Thank you! I missed that column. It wasn't checked to show.
(CID:94601344)
Posted: ‎2020-07-02 10:44 AM . Last Modified: ‎2023-10-31 10:14 PM
