Posted: 2020-07-05 08:12 PM . Last Modified: 2024-04-03 01:18 AM
Dear All,
I would like to know if the following setup is supported by Netbotz 455:
What I can find in kb FA256261 is maximum 3 USB camera supported but it doesn't state if additional 1 GSM modem would work?
Best Regards,
TJ
(CID:145851184)
Hi TJ,
Any maximum connection of a single sensor does not effect the number of potential connections of other USB devices, although it may slow down communications if you're maxed out. If a device supports 4 cameras, then it will always support those 4 cameras regardless of what other USB connections are made (of course you'll need a powered USB hub).
Please note that no new modems have been tested in some time and the k-base that notes the supported modems should be current:
http://www.apc.com/us/en/faqs/FA158359
Steve
(CID:145851250)
Hi TJ,
Steve
(CID:145851250)
Hi Steve,
Thanks for the prompt reply
BR,
TJ
(CID:145851781)
Posted: 2020-07-05 08:12 PM . Last Modified: 2023-10-22 03:19 AM
