NetBotz Room Monitor 355 serial port settings
  • EcoStruxure IT forum
  • NetBotz Room Monitor 355 serial port settings
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 11:23 AM . Last Modified: ‎2024-04-10 12:34 AM
1069
What are the serial port settings for the NetBotz Room Monitor 355?  The quick start guide does not list them?  I would like to use putty instead of the configuration utility.  Thanks
(CID:94603393)
  • NetBotz
1068
Hi Andrew,
The settings are as follows:
38400-8-N-1 None
The default login to the console is root   and  apc for the password
(CID:94603402)
1069
Hi Andrew,
38400-8-N-1 None
(CID:94603402)
Posted: ‎2020-07-02 11:24 AM . Last Modified: ‎2024-04-10 12:34 AM
(CID:94603474)
Posted: ‎2020-07-02 11:24 AM . Last Modified: ‎2023-10-31 11:26 PM
This is a heading
