Migrating DCE 7.2.2 to 7.2.6
  • Migrating DCE 7.2.2 to 7.2.6
129
72
Posted: ‎2020-07-02 11:24 AM . Last Modified: ‎2024-04-10 12:34 AM
715
It is possible to migrate a DCE 7.2.2 to a 7.2.6 directly? or do we have to go to 7.2.4 then to 7.2.5 to finally getting to 7.2.6?
(CID:94603407)
Replies 4
You will need to follow the upgrade path and go from 7.2.2 to 7.2.4 to 7.2.5 to 7.2.6 from what I understand.
(CID:94603409)
Yes, In order to upgrade from 7.2.2 to 7.2.6...It needs to be upgraded in order(ie., 7.2.2-->7.2.4-->7.2.5-->7.2.6).
(CID:94603411)
You can upgrade  directly from 7.2.2 to 7.2.6 but will loss  data saved, and start Exper like as a new device, if you not need data before to the new install is no problem, but if you need this. you cant do.
(CID:94603472)
Posted: ‎2020-07-02 11:24 AM . Last Modified: ‎2023-10-31 11:21 PM
