DCE and Hyper-V?
  • EcoStruxure IT forum
  • DCE and Hyper-V?
124
110
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-02 11:22 AM . Last Modified: ‎2024-04-10 12:35 AM
1136
DCE and Hyper-V?
Can DCE be installed on Hyper-V?
Did any of you managed to get it going on Hyper-V? How did you get that done?
(CID:94603307)
Replies 11
1135
Unfortunately, DCE is not officially supported on Hyper-V. DCE is only officially supported on a VMware platform.
There are tools to convert the OVA to a Hyper-V format, but even if this should work (I haven't heard of any success stories with this), it would not be supported by us.
DCE 8.0 will be a software based application that you can install on any OS, according to the server spec. I do not have the official release date for this version.  Thanks
Breda
(CID:94603326)
Any update to the release of DCE8? We have to maintain an ESXi cluster of 2 servers purely so we can run DCE v7, while the rest of our infrastructure runs on Hyper-V. Its not efficient.
(CID:105468676)
I´m running DCE on Hyper-V, both at customer site and in my lab. Everything is working OK, no issues at all. Instructions how to convert the OVI-file to VHD: https://social.technet.microsoft.com/forums/windowsserver/en-US/7e04f2bc-8fe7-4ce5-b7d2-bc89d91852e4...
(CID:95355287)
Hi Patrik! What version of Hyper-V and DCE you are use? Is there some specific settings for VM?
(CID:99156803)
Posted: ‎2020-07-02 11:23 AM . Last Modified: ‎2024-04-10 12:35 AM
I´m currently running Hyper-V on a Windows Server 2012 R2 and Expert v7.2.2. No specific settings, just assign memory, CPU and disk according to your need.
(CID:99157931)
Hello to all, one question please, did you try to upgrade your server?
Thank you.
(CID:129406303)
Posted: ‎2020-07-02 11:23 AM . Last Modified: ‎2024-04-10 12:34 AM
Hi!
I've tried to deploy more recent version of DCE on Hyper-V, but it dont work.
It seems that DCE 7.2.3. is last the version which can run on Hyper-V.
(CID:129406419)
Hello, I tried Hyper-V (inside Windows 10 - Pro), convert the OVA to VHD, it ran perfect, after create the VM in Hyper-V and deploy the converted VHD, I upgrade the server (for this test) from 7.4.2 to 7.4.3 without problem, the new 7.4.3 DCE for test works perfect.
(CID:130091825)
Erlinson Bravo Garcia
Can you please guide me how to to ova to vhd convert ?
Best regards
(CID:133371725)
https://blogs.msdn.microsoft.com/timomta/2015/06/11/how-to-convert-a-vmware-vmdk-to-hyper-v-vhd/
(CID:133375477)
Posted: ‎2020-07-02 11:23 AM . Last Modified: ‎2023-10-31 10:25 PM
This is a heading
