Posted: 2020-07-02 11:22 AM . Last Modified: 2024-04-10 12:35 AM
Hi, i want to know whether i can add my AHUs with BACnet IP protocol to Data Centre EXpert/DCO?
(CID:94603305)
Hi Shaf,
DCE does not directly support the BACNet IP protocol. DCE directly supports SNMPv1/SNMPv3/Modbus TCP and Netbotz. The BACnet device would have to be discovered through one of the above protocols. For this to work you would need to find a converter that can convert BACnet to Modbus TCP or SNMP.
Once you have this you need to provide the register map or mib to the Multivendor Support Team (multivendorsupport@apc.com) and request that a DDF be written that can monitor the BACnet devices via the converter.
Breda
(CID:94603347)
Posted: 2020-07-02 11:22 AM . Last Modified: 2023-10-31 10:17 PM
