Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: 2020-07-03 01:46 AM . Last Modified: 2024-04-09 12:29 AM
Dear Sir/Madam,
I have recently upgraded some NetBotz (NBWL455, NBRK450) from v4.4.0_20140827_1358 to the latest v4.5.1_20151117_1714 via AV4.5.1 in DCE v7.2.7. The whole upgrade process went okay and once the NetBotz get reconnected, I can see the firmware version is updated to the 4.5.1 as well as the sensor pod 150 Integrated firmware is updated from 0.6.5 to 0.6.9. Unfortunately, I have problems with the Camera Pod 160, the firmware version is still on v4.4.0 and it gave me an error message about "Pod Camera us unplugged or has malfunctioned"
I have tried Appliance Reboot in Advanced View, it actually fixed one of the NetBotz (NBWL455) camera pod, but I still have 2 NBWL455 Camera Pod 160 did not work. I would like to know if there is anything I should try on the system before I go to the site to power cycle the device.
James Rong
(CID:105470415)
Hello James!
Have you tried to re-upgrade the f/w trought the Advanced View?
If you didnt yet, give it a try... if you already tryed, u might save a backup from your alerts and configs, and go for a connection on console, and do the reset process...
I ll look for some references about the reset via console for you.
Edit: The link with instructions for console flashing.
Att.
Emenson Reis
(CID:105470418)
Hi, Emenson,
Thank you so much for your reply. I would like to know how should I re-upgrade the f/w through Advanced View? When I click "Upgrade" in AV, it has detected the firmware is 4.5.1, the Install Component checkbox is greyed out too. If there is a different way in AV to re-upgrade the FW, could you please advise? Thanks a lot
James Rong
(CID:105470582)
Hi James! There is no way to re-uprgade or downgrade Netbotz firmware via Advanced View. You need to flash firmware via tftp, see Emenson's link for details.
(CID:105470583)
Hello James!
Did u managed to re-flash via tftp?
I was checking on my Advanced View and you're right, we cant reflash trought the Adv View.
But via Hyperterminal console following the steps on the link i provided, you'll easly solve that matter.
If u need help, just scream 😂
(CID:105471008)
Posted: 2020-07-03 01:46 AM . Last Modified: 2023-10-31 11:26 PM
