Can I specify the Y axis for graphs?
  • Can I specify the Y axis for graphs?
129
72
Posted: ‎2020-07-03 01:46 AM . Last Modified: ‎2024-04-09 12:29 AM
837
I'm trying to create graph for Jan/Feb/Mar for temperature in the lab however the Y axis which is degrees F varies between each month making these graphs look very different.  The same sensors are being used in each case and the temperatures are roughly the same.  Is there any way to specify the low and upper temperatures to base the graph on so I can generate graphs which are consistent?
I'm currently using Struxureware data center expert 7.2.7 right now.
(CID:105470443)
Posted: ‎2020-07-03 01:47 AM . Last Modified: ‎2024-04-09 12:29 AM
Hi Joe,
Sorry, choosing the Y axis range is not a capability in the graph as initially created. If you are sending the graph in e-mail format, they will come out based on the highs and lows on the sensors. If you're looking at the graphs in the DCE UI application, you can always highlight a section of the graph and that will also in turn select the high and low range. Perhaps a better option would be to export the data and import it into a graphing tool such as Microsoft Excel.
I can forward this in as an enhancement request but you should know that something like this may not be addressed in the very near future.
Steve.
(CID:105470458)
Hi Joe,
Steve.
(CID:105470458)
Posted: ‎2020-07-03 01:47 AM . Last Modified: ‎2023-10-31 10:18 PM
