NetBotz 570 not able to boot up
  • NetBotz 570 not able to boot up
129
72
Angwenyi
Lieutenant JG Angwenyi
Lieutenant JG
Posted: ‎2021-08-06 01:08 AM
1504
Dear Team,
I have a customer NetBotz 570 which has been working fine for 3yrs, now it can't boot up.
I used HyperTerminal for troubleshooting and it seems the loading process stops just after powering on as attached.
Kindly any way am able to login and restore the unit.
Thank you.
Regards
  • NetBotz
tjlaw
Lt. Commander tjlaw Lt. Commander
Lt. Commander
Posted: ‎2021-08-16 12:09 AM
1
1483
You might want to check out the restore procedure as follows:
https://www.apc.com/us/en/faqs/FA176133/
It's best to check if you have a valid backup with you.
If you have a valid support contract, you can always contact your local support to help on resolving the issue.
Else if you are interested, you can move forward to using Netbotz 750 as a new replacement.
BR,
TJ
Angwenyi
Lieutenant JG
Posted: ‎2021-08-16 05:30 AM
In response to tjlaw
Hi TJ,
Thank you for your response.
I guess then it's dead, it can't go beyond the previously attached step.
Felix
