DCE SOAP API using python
Select a Country
  • DCE SOAP API using python
Cory_McDonald Champion
160
Jef Leader
114
gsterling Mentor
77
Posted: ‎2021-08-14 06:23 AM
3676
Hello All,
I am trying to use SOAP API to test getting sensor values from DCE using python.
I am using the V2_0 WISDL services
1) Use "initializeSensorService" to initialize the service - This returns true
2) Used getSensorsForDevice to get all the sensors available for a device by giving device id.
Now I want to receive sensor data using getSensordata by providing a corresponding sensor id. But I am getting missing ISXCElement ID.
I tried the python request module:
from requests.auth import HTTPBasicAuth
from requests import Session
from zeep import Client
from zeep.transports import Transport
def main():
    user = "XXXXXX"
    password = "XXXXXX"
    session = Session()
    session.verify = False
    session.auth = HTTPBasicAuth(user, password)
    client = Client('https://XX.XX.XX.XX/integration/services/ISXCentralSensorService_v2_0?wsdl', transport=Transport(session=session))
    response=client.service.getSensorData('SENSOR ID')
    print(response)
Does anyone have any Python examples of pulling information via the SOAP API from Expert?
Shaun
Shaun Leader
Leader
Posted: ‎2021-08-16 01:38 AM . Last Modified: ‎2021-08-16 01:48 AM
3653
Hi @Anonymous user,
I had a similar problem with zeep - it's something to do with how it's mapping named parameters (in the API) to positional parameters, in this specific example ISXElementID ends up not being the first parameter, locale does.  Try:
 response=client.service.getSensorData('?', 'SENSOR ID')
Sending the API ? for a locale will request the default locale (there is only one locale on the API last I looked, so I'm happy with the default).  Then your sensorID becomes the second positional parameter and it should be much happier.
Replies 5
Shaun
Shaun Leader
Leader
3654
Hi @Anonymous user,
Posted: ‎2021-08-16 04:41 AM
In response to Shaun
3646
Thank you so much Shaun for the solution and correct explanation of the problem.
Angwenyi
Angwenyi
Explorer
Posted: ‎2021-08-16 04:59 AM
In response to Anonymous user
3639
Hi Mousumi,
Thank you for your question, I have a customer who is unimpressed with DCE dashboard and want's information displayed in their own format for display at their NOC.
Was just following your trail and wondered if SOAP API could be the solution for my customer problems, if am able to just pick the particular sensors for certain devices to display on their dashboards the way they want it.
Thank you and looking forward to your reply on the same.
Felix
Shaun
Shaun Leader
Leader
Posted: ‎2021-08-16 07:01 AM
In response to Angwenyi
1
3633
Hi @Angwenyi,
That does sound like something that should be achievable with the web-services API.
You can find documentation on the available methods & a manual of the data model at:
https://www.se.com/ww/en/product/SFWEBSVC/struxureware-data-center-expert-web-services-api/
https://dcimsupport.ecostruxureit.com/hc/en-us/articles/360039289673-Data-Center-Expert-Web-Services...
Angwenyi
Angwenyi
Explorer
Posted: ‎2021-08-17 02:27 AM
Hi Shaun,
Thank you for your prompt response.
Probably I should explain what my customer need, they want us to individualize alert display for each equipment.
For example UPS 1 should have it's own portlet showing all alerts showing just for that UPS for instance number of warning and critical alarms for UPS 1.
Same will apply for the other devices of their choice.
I hope my explanation is vivid enough however let me know if I should clarify further.
Thank you.
Felix
