Posted: 2020-07-04 12:20 AM . Last Modified: 2024-04-05 04:37 AM
Is there any particular formatting for the "Share" and "Subdirectory" are entered?
Perhaps someone might have an example or picture of how the fields look like in the Add Backup part of NFS backup share settings?
I get a very generic "The share was unable to be mounted. Please check your settings."
(CID:126162253)
Hi lshiffner,
In brief, for example, we have a server with an IP address of 10.3.33.100, which provides several NFS resources. One of these NFS resources (snared foder) on this server has a relative path export/DCIM_backups. But we do not make a backup copy to the DCIM_backups folder, but to a certain subfolder sxwdce-kv0.back, i.e. to the export/DCIM_backups/sxwdce-kv0.back. Here is a screenshot from the working system:
I hope this helps you.
With respect.
(CID:126162384)
Hi lshiffner,
With respect.
(CID:126162384)
Posted: 2020-07-04 12:21 AM . Last Modified: 2024-04-05 04:37 AM
Hi lshiffner,
Have you been able to solve this issue or not?
With respect.
(CID:126164000)
Posted: 2020-07-04 12:21 AM . Last Modified: 2023-10-22 03:08 AM
