Comparison Method violates its general contract Error message
  • EcoStruxure IT forum
  • Comparison Method violates its general contract Error message
124
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 12:21 AM . Last Modified: ‎2024-04-05 04:37 AM
1382
Dear Fellows,
I am running DCE 7.4.3 with no problems but sometimes I get Comparison Method violates its general contract Error message; Please advise.
Kindly find the attached Error message
(CID:126162351)
Replies 11
1382
Hi Sameeh,
I'll defer to anyone else if they've seen this before but I've never seen that error.
What operating system is the client installed on?
How often does the error occur?
Have you installed the client on another OS to see if it specific to that client computer?
Do you have another DCE server that you can connect to? Does it also have the error?
What exactly are you doing at the time the message occurs?
Can you get the log? It will be located in a directory such as:
C:\Users\\.isxc\7.4.3\.metadata\.log
Steve
(CID:126162720)
Hi Steven,
Thanks  for your Reply Kindly find below the answers for your queries:
1- What operating system is the client installed on? Windows 10 (64 bit).
2- How often does the error occur? About one time per Hour.
3- Have you installed the client on another OS to see if it specific to that client computer? Yes, my Laptop (Windows 7 (64 bit)) and I am facing the same issue.
4- Do you have another DCE server that you can connect to? Does it also have the error? No, I don't have another DCE Server.
5- What exactly are you doing at the time the message occurs? I don't remember but I'll try to notice then get back to you.
6- Can you get the log? It will be located in a directory such as:
C:\Users\\.isxc\7.4.3\.metadata\.log Kinldy find below the content of the .metadata folder on my laptop I only have .plugins folder and an unnamed Text file. I don't have an access to the client site but I will try to get the Log files once I am there
(CID:126163020)
Posted: ‎2020-07-04 12:21 AM . Last Modified: ‎2024-04-05 04:36 AM
Hi Sameeh,
Please note there is a text file in that folder as well. I'm assuming you have not changed your folder options and are hiding file extensions. If you can change your settings to view file extensions, you will see it is simply ".log". Here's an example of how I have my system configured and what I can see:
Steve
(CID:126163204)
Hi Steven,
Thanks for your reply, I will send you the log file by email
(CID:126163230)
Hi Sameeh,
I don't see anything in the log other than the same messages, just a little more detailed. Basically the error is stating if A>B and if B>C, then A>C. That's just the logic of it of course, no specific data on what it actually is comparing is available in the log.
First thing I suggest is to reboot the server. It may simply be some invalid information stuck in memory.
If you Have the ability on this site, spinning up another VM quickly to see if you can replicate the issue would be a good troubleshooting step to verify if the issue is client side or server side. I'm assuming at this point it is server as multiple clients show the error but I guess it could also be something installed on these client systems.
After that, I suggest maybe escalation through your regional tech support people. If you're not aware whom they may be, I can try to put someone in touch with you to get this escalated as I can only escalate NAM issues at this time.
Steve.
(CID:126163242)
Posted: ‎2020-07-04 12:22 AM . Last Modified: ‎2024-04-05 04:36 AM
Hi Steven,
  • Ok. I will reboot the server once I get the access to that Site.
  • BTW the DCE server is a physical Server not VM.
  • I will appreciate if you sent me the contact of Regional Tech Support for Escalation if needed.
BR,
Sameeh
(CID:126163254)
Hi Sameeh,
I don't think virtual vs hardware matters at this point and since the trial VM is free, it'd be a semi-easy way to validate.
Where are you, Egypt?
Steve
(CID:126163259)
Hi Steve,
I'll check the availability of spinning up a VM.
Yes, I am in Egypt.
BR,
Sameeh
(CID:126163265)
Hi Sameeh,
I just wanted to follow up on this issue, as I am also in the EMEA region. Have you managed to reboot the server yet, and if so, are you still seeing the same issue?
(CID:126167725)
I'm also getting this error somewhat frequently.  it occurs after adding custom properties to multiple sensors.  After it happens i'm locked out of seeing sensor details... i've had to reboot the server to get it back to normal.
(CID:137106242)
Posted: ‎2020-07-04 12:22 AM . Last Modified: ‎2023-10-20 05:09 AM
