Missing Syslog Unsucessful Authentication Attempt
  • Missing Syslog Unsucessful Authentication Attempt
126
65
Posted: ‎2020-07-05 11:27 PM . Last Modified: ‎2024-04-03 12:08 AM
1145
Hello everyone,
I am currently working on the Monitoring capacities of the Netbotz Rack Monitor 250. I need to check if the Rack Monitor is able to provide syslog monitoring data when an unsucessful Authentication Attempt is done. To be noted, the syslog has been enabled on the Netbotz.
This could be triggered by:
  • a correct login, wrong password
  • an incorrect login
I have performed some tests on my Netbotz, but sadly, I did not see any syslog returned to my monitoring PC. (checking tail -f /var/log/messages)
Do you confirm that the Rack Monitor does not return any syslog message when an unsuccessful authentication attempt is performed ?
Do you know any work-around possible to get the information regarding the unsuccessful authentication attempt ?
I thank you in advance for the answer you will provide to my questions.
Best Regards,
rf2019
(CID:151065098)
  • DDF
  • NetBotz
  • bug
Posted: ‎2020-07-05 11:27 PM . Last Modified: ‎2024-04-03 12:07 AM
Hi Raphael FLAMENBAUM, sorry to leave you hanging.
If you're still seeing this issue, I recommend you contact your local tech support.
Stine
(CID:152570135)
I do not have any answer yet.
Do you know if APC Schneider Electric provides an exhaustive list of syslog messages provided by the Rack Monitor NetBotz 250 ?
Best Regards,
rf2019
(CID:152570658)
Posted: ‎2020-07-05 11:27 PM . Last Modified: ‎2023-10-22 03:03 AM
