How to get hardware information (Netbotz 250)
  • How to get hardware information (Netbotz 250)
129
72
Posted: ‎2020-07-05 11:27 PM . Last Modified: ‎2024-04-03 12:07 AM
2875
Hello every one,
I am currently working with the Netbotz 250 Rack Monitor and I have to be able to get the following information regarding this equipment:
  • Rack Monitor Identifier / Name
    Note: How do you configure the Rack Monitor name ?
  • Rack Monitor Hardware Version
  • Rack Monitor Serial Number
Until now, I have not been able to retrieve them via SNMP, syslog, ssh command.
I might, for sure, have done it wrong.
Therefore, would you know the different snmp OID or ssh commands to use to get such information?
I thank you in advance for the consideration you may pay to my request.
Best Regards,
rf2019
(CID:151065111)
  • DDF
  • IT Expert
  • NetBotz
  • Portal
  • bug
2875
Hello Raphael,
Login via SSH and run the about command.  You will receive a list of results (you may need to scroll up to see them all).
There are results for: Model Number, Serial Number, and hardware revision within the HardWare factory section of the about command results.
Also, please ensure that your NetBotz 250 firmware is up-to-date.
Cory
(CID:151065124)
2876
Hello Raphael,
Cory
(CID:151065124)
Thank you so much.
It did work.
(CID:151584999)
Posted: ‎2020-07-05 11:27 PM . Last Modified: ‎2023-10-22 02:31 AM
