Posted: 2020-07-04 07:51 PM . Last Modified: 2024-04-04 11:05 PM
HI, I'm building a number of rooms in DCO, tyhe Doors available in Room Fixture all swin inwards (into the room).
All doors in my rooms swing outwards (out of the room).
Is there a way to either rotate the door, or select another door type, so that the door swings outside the room?
thnx
billd
(CID:132661101)
Posted: 2020-07-04 07:52 PM . Last Modified: 2024-04-04 11:05 PM
Hi Bill,
Drag the swing door from outside of the floor layout, and it should snap to the outer wall, to model door opening outward.
(CID:132661106)
Hi Bill,
(CID:132661106)
Thnx, that worked with a new door being added from the genome. It appears that once you add a door it keeps the same orientation with no way to change it. Need to delete it and add a new one again.
thnx again
billdfor the "top" wall, but I can't rotate the door (or flip where the door entrance is).
eg. I want to add the 'bottom' wall
(CID:132661116)
Hi Bill,
You are right, on both counts.
The only way I can edit door placement is by deleting / re-adding it as well.
Could I trouble you to fill in a feature request to rotate door with your details?
Thanks!
(CID:132661126)
Hi Chris, no probs,
thnx
for the help,
cul
billd
(CID:132662251)
Posted: 2020-07-04 07:52 PM . Last Modified: 2023-10-22 02:48 AM
