DCE intermittent freezing after VM migration
  • DCE intermittent freezing after VM migration
128
Posted: ‎2020-07-04 07:50 PM . Last Modified: ‎2024-04-04 11:05 PM
1201
Hi we have a customer whop has recently migrated from running DCE successfully on ESXi5 to ESXi6.5.  Since the migration the DCE server intermittently hangs and has to be restarted 'manually'.
The migration process was as follows:
  • Take a full backup from the 'old' DCE server
  • Deploy the 'demo' version of DCE using the OVA file to the new VM platform.  Set up the NIC to use the same MAC address as the old one.
  • Switch off the old DCE server.
  • Restore the old backup into the new DCE server.
  • The old server is no longer running (it has been deleted too as far as I know)
This all appears to have worked but the freezes continue.
Any advice on how to prevent the freezes please?
Regards
(CID:132660978)
Replies 9
Hi.  Any update / response on this please?
(CID:132662643)
Any comments on this please? Our customer is getting very frustrated about this.
(CID:132669345)
Posted: ‎2020-07-04 07:51 PM . Last Modified: ‎2024-04-04 11:05 PM
Hi - any assistance available yet please?  I have more information below too if it helps.
Virtual Machine details
Hypervisor: ESXi 6.5u2
Physical Hardware:
Dell PowerEdge R6415
AMD EPYC 7551P 32-Core Processor
512GB RAM
VM Virtual Hardware
Links to other files below
Server logs
Capture logs
Last backup from server (2.2GB)
(CID:132670905)
More information - possibly a direction to look?
https://access.redhat.com/articles/65431
Given that CentOS 6 is based upon RHEL 6, and DCE is built ipon CentOS 6? the table i the link above suggest that CentOS 6 is not compatible with AMD EPYC processors?
This seems to be related to running RHEL on the physical hardware not on the Virtual Hardware.
Can you confirm if DCE can run on EPYC processors on Hypervisor: ESXi 6.5u2?
If not any workaround known?
(CID:132670922)
Hi Garry,
I am working with the customer directly to try to resolve this.
Regards
John T
(CID:133367580)
Thank you, can you keep me up to date with progress on this please
(CID:133367866)
Hi John - can you advise if this has been resolved please?
(CID:134028214)
Hi Garry,
Unfortunately, not yet. We haven't been able to pinpoint the exact cause.
We were suspecting a storage issue initially, but it might be a compatibility issue now. We've asked the customer to deploy another DCE VM, without adding any devices to it, and leave that running for a while to check if the same thing happens with that. Awaiting feedback from them soon.
Regards
(CID:134028583)
Posted: ‎2020-07-04 07:51 PM . Last Modified: ‎2023-10-22 01:25 AM
