Posted: 2020-07-06 12:21 AM . Last Modified: 2024-04-02 11:36 PM
Actually I have project done since 5 years. The project is vijeo citect and modicon M340 ( industrial automation).
we are in 2020, there is a tools in schnieder helps me to do the integration with IBM maximo.
IBM Maximo for maintenance operations assets.
it is be a trend in Saudi Arabia to do this kind of integration.
(CID:153092321)
Dear Mohammad Nofal,
As Jef Faridi explained in a similar post :
We do not have direct 'integration' interface for that - but depending on what you would like to import or export, there might be some possibilities via ETL (ETL - Extract Transform Load). The ETL interface will allow relationships to be formed to externals systems like SQL databases, and/or flat files (among other systems).
I hope this will be useful to you.
With respect.
(CID:153092345)
With respect.
(CID:153092345)
Okay, it’s make sense.
So, the related question is which type of ETL we need to use?
they are 6 type of ETL? Then how we can get this software
(CID:153092401)
Posted: 2020-07-06 12:22 AM . Last Modified: 2023-10-22 02:46 AM
