Dear Community Members, We are currently experiencing a technical issue that is affecting the ability to create new posts. Our team is actively investigating the root cause and working to resolve it as quickly as possible. We apologize for the inconvenience and appreciate your patience. SE Community Team!
Posted: β2020-07-03 04:49 PM . Last Modified: β2024-04-08 12:25 AM
(CID:120131039)
Hi cabaker,
Maybe my questions are simple, but after what events or changes did this happen?
If the local display is connected using a cable with an RJ-45 connector, tried to disconnect it and reconnect it?
Probably, your cooling unit is on warranty support? Have you contacted the local Schneider Electric technical support on this issue?
With respect.
(CID:120131471)
Hi cabaker,
With respect.
(CID:120131471)
I thought the display was hard wired and now see the RJ-45. After unplugging and re plugging issue is resolved. Now that i feel like a dummy. Thank you and have a great day.
(CID:120131469)
I'm glad that my advice helped you to find a solution π.
(CID:120131479)
Posted: β2020-07-03 04:49 PM . Last Modified: β2023-10-22 02:44 AM
