Posted: 2020-07-04 02:17 AM . Last Modified: 2024-04-05 03:52 AM
is it possible to export the local genome library of DCO and then import it in other server?
(CID:126180219)
Hi Javier,
Yes, it is possible to export and import the Genomes library.
To export, go to File > Export > Genome
To import, go to File > Import > Genome
NOTE: it is recommended to take a fresh backup file before starting the import job.
Kind regards
(CID:126180246)
Hi Javier,
Kind regards
(CID:126180246)
Posted: 2020-07-04 02:17 AM . Last Modified: 2023-10-22 02:42 AM
