ITA 9.3.x or later syslog support
  • EcoStruxure IT forum
  • ITA 9.3.x or later syslog support
124
65
Back to EcoStruxure IT forum
tjlaw
Lt. Commander tjlaw Lt. Commander
Lt. Commander
Posted: ‎2024-02-19 01:31 AM
1098
Dear Community,
Is syslog export supported in ITA 9.3.x or later version?
Thank you.
BR,
TJ
  • DCIM Support
  • IT Advisor
Captain
Posted: ‎2024-02-20 03:25 AM
Hello TJ, customers may setup rsyslog export from ITA servers.
Schneider installs a file in /etc/rsyslog.d named “operation-logs.conf”. On some older ITA releases customers must first edit this file and comment a few statements to allow rsyslog forwarding to work. The below edits are not necessary in the 9.4.x versions of ITA and newer.
  • You will need to edit the operation-logs.conf file, and comment the three lines containing the word “stop” by placing a “#” character on those lines before the word “stop”.
  • Save the changes.
To forward syslog entries on your ITA server to an external source.
Edit /etc/rsyslog.conf.
Add the forwarding directive in this format. You should be able to place this line at the bottom of the rsyslog.conf file.
*.* @@<remote-server>:<remote-port>
The above line will cause all messages written to syslog to be forwarded to "<remote-server>" on port "<remote-port>"
Then restart the rsyslog service
systemctl restart rsyslog
Regards
Greg Sterling
Admiral
Posted: ‎2024-02-22 04:59 AM
Hi TJ,
In latest version(s) of ITA, there seem to be included some option/settings for remote logging.
You might want to edit the config file: /etc/rsyslog.conf
and look for the following lines (at the end of the file):
# Remote Logging (we use TCP for reliable delivery)
# remote_host is: name/ip, e.g. 192.168.0.1, port optional e.g. 10514
#Target="remote_host" Port="XXX" Protocol="tcp"
(remove this # , when doing your configuration),
Kind regards,
Captain
  • Save the changes.
Regards
Greg Sterling
Admiral
Hi TJ,
Kind regards,
Dayanand
Dayanand
Cadet
Posted: ‎2025-06-25 10:14 PM . Last Modified: ‎2025-06-25 10:44 PM
Hi All,
We are using ITA 9.5.1. I have edited the line in rsyslog.conf as Target="remote_host" Port="XXX" Protocol="udp".
I am trying to use UDP instead of TCP.  I have removed # sign at the beginning of line and also removed inverted commas enclosing target host, port and protocol.
Restarted the service using -> systemctl restart rsyslog
Still no logs are reported on our SIEM server.
Let me know if I am missing something. Do we also need to edit below lines as well and remove # sign to enable UDP reporting.
# Provides UDP syslog reception
# for parameters see http://www.rsyslog.com/doc/imudp.html
#module(load="imudp") # needs to be done just once
#input(type="imudp" port="514")
Dayanand
