Posted: β2020-07-04 12:47 AM . Last Modified: β2024-04-05 04:27 AM
HELLO I TRY TO ACCESS TO MY DCO CLIENT BUT GENERATE THIS ERROR:
IMPOSSIBLE TO VALIDATE USER CREDENTIALS. SEE THE DETAILS OF
REGISTRATION OF THE APPLICATION
IΒ΄M VALIDATE AN ALL SERVICES ARE RUNNING
(CID:126165068)
Posted: β2020-07-04 12:48 AM . Last Modified: β2024-04-05 04:27 AM
CURRENT VERSION 8.1
(CID:126165244)
Hi Omar,
It seems you are trying to connect via port 80, but DCO configured to respond using SSL connection (via port 443). You can select the SSL connection in Advanced Settings:
Kind regards
(CID:126165248)
Posted: β2020-07-04 12:48 AM . Last Modified: β2023-10-22 02:39 AM
