PCOWEB - DCE - Uniflair TDAV1622A
  • PCOWEB - DCE - Uniflair TDAV1622A
126
65
Posted: ‎2020-07-04 12:48 AM . Last Modified: ‎2024-04-05 04:27 AM
2749
We try to connect by SNMP Data center expert and uniflair TDAV1622A. But only recognize like Linux/server and only can see connection status. There is any configuration to do on SNMP setting at PCoweb card?
(CID:126165375)
Replies 6
Hi David Sánchez López,
Please, what is your version of DCE-server?
With respect.
(CID:126165379)
Hola David.
In order to monitor Uniflair units with pCOWeb card you need to use Device Definition File (DDF) for the DCE. The html webpage is also should be uploaded to pCOweb-card.
The DDFs and html pages is available at http://webcard-it.schneider-electric.com (registration is needed).
There are also some useful manuals at that resource like this one ->http://webcard-it.schneider-electric.com/Connection_to_struxureWare_example.pdf
(CID:126165386)
  • configuration settings for SNMP OID the answer take time
  • esas paginas no estan disponibles
  • Hi tea
  • Hi team
  • HTML frame for leonardo model
  • there is another way to request the identification (login and password) auther than the Email: pcoweb@schneir-electric.com to acces the Uniflair portal to download the files for pcoweb (MIB
The DCE version is StruxureWare Data Center Expert 7.4.1
(CID:126169291)
Hi David
You should also configure baud rate in PCO web and in the control unit (through local display). Default baud rate in PCOweb is 19200 bps and baud rate of controller 1200 bps. Change the baud rate in PCOWEB same as controller baud rate (1200 bps). if not, it would be  not communication betwen PCO WEB card and controller or you only read the PCO Status in your DCE.
(CID:126165409)
Posted: ‎2020-07-04 12:49 AM . Last Modified: ‎2024-04-05 04:27 AM
Now is working, first update web pages to pcoweb, download DDF files in SNMP and add definition files to DCE. After that DCE recognize the uniflair unit.
Thank's for your help,
This page need to be very visible at web
(CID:126165438)
Posted: ‎2020-07-04 12:49 AM . Last Modified: ‎2023-10-22 03:29 AM
