Posted: 2020-07-04 05:17 PM . Last Modified: 2024-04-04 11:58 PM
is it possible to integrate Ecostruxure with IBM Maximo platform? Which are the requirements to do this?
(CID:131335860)
Hi Carlos,
We do not have direct 'integration' interface for that - but depending on what you would like to import or export, there might be some possibilities via ETL (ETL - Extract Transform Load). The ETL interface will allow relationships to be formed to externals systems like SQL databases, and/or flat files (among other systems).
Kind regards
(CID:131958940)
Hi Carlos,
Kind regards
(CID:131958940)
Posted: 2020-07-04 05:17 PM . Last Modified: 2023-10-22 02:39 AM
