Posted: 2020-07-04 05:16 PM . Last Modified: 2024-04-04 11:58 PM
After either uploaded a key file or a certificate file, Webmin responded with error:
Missing parameters. -cKeyFile=/path/to/key/file ; -cFile=/path/to/cert/file.
Any idea where to overcome this?
(CID:130683485)
Posted: 2020-07-04 05:17 PM . Last Modified: 2024-04-04 11:58 PM
Hi Jimmy,
Perhaps it is not in expected format, as described in the following page: Changing SSL certificate on the server
For you to be able to change to your SSL certificate on the DCO server, it needs to be an Apache 2.x/PEM format certificate consisting of two files (*.key, *.crt).
Kind regards
(CID:130683550)
Hi Jimmy,
Kind regards
(CID:130683550)
Posted: 2020-07-04 05:17 PM . Last Modified: 2023-10-22 04:33 AM
