Posted: β2020-07-03 07:40 AM . Last Modified: β2024-04-08 04:07 AM
There is a heading for Humidity Sensors under the Sensors tab on the web client in v8.0.1.
Is this something that can currently be displayed, if so how, or is it an imminent release?
(CID:110004244)
Posted: β2020-07-03 07:40 AM . Last Modified: β2024-04-08 04:06 AM
Hi James,
I was wrong, it seems there was a delay in my tests (I'm really sorry for the wrong info) - this morning I could see both the desk top client and the web client showing the "Humidity Sensor data", some screen captures from my DCO 8.0.1 setup:
I will find out about this "delay" time for the first time association (eg. sensor update in web client) and get back to you soon.
Kind regards
(CID:110004320)
Hi James,
You are right, the web client doesn't show the Humidity Sensor data - I will capture this as a software bug (so it can be fixed in a future version, must likely after 8.0.2).
Thank you
Kind regards
(CID:110004257)
thanks Jef Faridi . Does this mean Humidity data can be displayed in v8.0.1 on the client?
(CID:110004261)
You are welcome James, Yes, I could see the Humidity Sensor data (reported from DCE) in my 8.0.1 desktop client (screen capture attached). Kind regards
(CID:110004313)
Hi James,
Kind regards
(CID:110004320)
Thanks for the screenshots. Having checked again today I can see humidity sensors.
(CID:110004346)
You are most welcome James, Great! happy to hear that it is working for you too & many thanks for the update. I've been told that the humidity sensor data, similar to temperature sensor readings, if they have been successfully retrieved from external system/DCE, then they should show up. (apparently the delay in my tests might have been caused by some background jobs). Kind regards
(CID:110004347)
Posted: β2020-07-03 07:40 AM . Last Modified: β2023-10-22 02:36 AM
