Posted: β2020-07-05 07:46 PM . Last Modified: β2024-04-03 02:32 AM
(CID:144313009)
Sean,
Depending on the state of the server, the web commands may not work, you can try using the following URL to reboot the server: http://_
Replace <_server_name>_ with the ip address of your Data Center Expert appliance.
As an FYI, v7.0.0 was released in 2011. More information on releases can be found here. I highly recommend bringing your system up-to-date. Contact your local technical support for software support verification to receive upgrade files.
If you still experience problems after a reboot, you will want to reach out to your local technical support for further assistance.
Kind Regards,
Cory
(CID:144313044)
Thanks Cory,
I tried that but it doesn't succeed, I'll just have to wait until I get someone to that site to physically reboot.
and yes I will be upgrading to 7.6.0 soon.
SeΓ‘n.
(CID:144313049)
Posted: β2020-07-05 07:46 PM . Last Modified: β2023-10-22 02:33 AM
