Posted: 2021-02-21 05:48 PM
Is there a way to integrate a third party API with the DCE? There are only few status to be monitored through this API.
Thank you.
Posted: 2021-02-22 05:06 AM
Hi @Warne ,
The API available through DCE is for monitoring DCE and it's devices. Your question however seems to be more related to DCE using an API to monitor a 3rd party device. Sorry but there is no option for this. DCE can monitor SNMP and modbus 3rd party devices. It does use an API to monitor NetBotz devices however that is a built-in functionality and not outwardly exposed for use with other systems.
Hi @Warne ,
Posted: 2021-02-23 04:59 AM
hi @Anonymous user ,
I'm not sure if that's a question or statement but yes, that's true. If you need information, it can be found here:
https://dcimsupport.ecostruxureit.com/hc/en-us/sections/360006467394-DCE-web-services-API
Posted: 2021-02-23 09:53 PM
I want to make a website, which will be a sort-of search engine. A user enters a search term in a text box, and that data will be sent to several third party API's as query. Because the API's of course don't return completely similar responses, the data has to be parsed.
