Posted: 2020-07-04 03:15 AM . Last Modified: 2024-04-05 03:34 AM
One of my customer wants to display a power path screen, for overviewing the power grid in a simple way.
The screen should show the main grid, the switchgears, genset, ups, and which line is powered, etc. The map view in not enough in the DCE where, I can import a simple line diagram, and show the state of the switchgears, and the state of the different power line. I need a live scada screen, where the power lines are green, when they are powered.
Can someone give me an advice how to do that? Or can you show me the best way to do that? Maybe screenshots for examples.
Regards, Gabor
(CID:126887079)
Hi Gabor,
I was wondering perhaps products like EcoStruxure™ Power Monitoring Expert or EcoStruxure™ Power SCADA Operation might be something you are looking for.
Kind regards
(CID:127534829)
I have found the same product lines, the customer has a middle size data center. I don’t know this product line, but it seems to me, that EcoStruxure™ Power SCADA Operation is for bigger factory’s.
If somebody has set up something like this for a data center it will be nice to see few screenshot.
Regards, Gabor
(CID:128059170)
Posted: 2020-07-04 03:15 AM . Last Modified: 2023-10-22 02:29 AM
