How to delete devices from ecostruxure
Showing results forΒ
Did you mean:Β
  • How to delete devices from ecostruxure
129
72
Posted: β€Ž2020-07-05 12:29 PM . Last Modified: β€Ž2024-04-04 12:51 AM
2113
Is there a way to delete inactive gateways or devices from EcoStruxure? I've used severeal servers while performing tests and somehow it seems that all of the servers are still here yet inactive and not needed.
Any advice?
(CID:134681109)
  • IT Expert
2112
Hi Nebojsa,
Here is how to remove/delete device(s) from EcoStruxure IT Gateway:
Login to EcoStruxure IT Gateway,
and go to Devices (1)
select/click on device(s) you want to remove (2)
and then click on the DELETE button (3):
and how to remove a gateway:
You need to log in to your management (https://app.ecostruxureit.com/manage)  - Management can also be launched from your gateway (EcoStruxure IT (1) > Management (2)):
After login to the Management, go to Settings > Gateways (1), and click on a gateway that you want to remove (2):
and then click on Disconnect:
Kind regards
(CID:134681383)
Replies 4
2113
Hi Nebojsa,
Kind regards
(CID:134681383)
Posted: β€Ž2020-07-05 12:30 PM . Last Modified: β€Ž2024-04-04 12:51 AM
Hello Jef,
That's one option I didn't try πŸ˜€
You were very helpful. Thanks for your help πŸ˜€
Nebojsa
(CID:134681542)
Hi Nebojsa,
You are most welcome - glad to hear that it helped πŸ˜€
Kind regards
(CID:134681544)
Posted: β€Ž2020-07-05 12:30 PM . Last Modified: β€Ž2023-10-22 02:29 AM
