How to configure 355 CAM display screen values
  • EcoStruxure IT forum
  • How to configure 355 CAM display screen values
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-04 03:06 AM . Last Modified: ‎2024-04-05 03:37 AM
952
I can see the rotation of humidity and temperature values on Netboz 355 camera digital screen before but now there is no rotation.
How can i change this and get it display with ° C values instead Fahrenheit .
Shaik Mahboob Ali
(CID:126884628)
  • NetBotz
952
Hi Shaik,
The LEDs on the front of the unit coincide with the regional settings of the unit. AS you can see here, I've chosen English UK:
This was originally English US and it was flashing 81 degrees. After changing this to the setting above, the unit rebooted and just as it came back on line, it is now showing 27 degrees.
Steve
(CID:126885257)
953
Hi Shaik,
Steve
(CID:126885257)
(CID:126886050)
Posted: ‎2020-07-04 03:06 AM . Last Modified: ‎2023-10-22 02:27 AM
