Posted: 2020-07-04 03:33 AM . Last Modified: 2024-04-05 03:17 AM
Hi Team ,
We know it can modify the language on DCE client ,when I changed to en version ,
I found the web client still not changed , can someone advice on how to change language on web client ? Your input would be appreciated.
Best Regards
(CID:128061106)
Dear Chu Li Wei,
To resolve your issue, you need to change the Server Locale parameter accordingly.
This can be done through the DCE-client in the System -> Server Administration Settings... -> Time Settings... menu on the Regional Settings tab.
I hope this helps you.
With respect.
(CID:128061144)
Dear Chu Li Wei,
With respect.
(CID:128061144)
Hi Chu Li Wei,
I'd also try changing the language setting in the browser. As you can see here, changing the DCE server setting as Spezialist noted changes things like the widgets/gadgets in the page:
But it appeared that only after I changed the browser settings did other things such as some of the menus change:
Steve
(CID:128061300)
Hello Spezialist & Steve ,
Thanks for your kindly response , I tried to change the Server Locale and
the info as blue area was changed successed but the red area still not
changed , could you kindly advice on how to changed it for the red area?
Thank you.
(CID:128065840)
Posted: 2020-07-04 03:34 AM . Last Modified: 2024-04-05 03:17 AM
Dear Chu Li Wei,
With respect.
(CID:128065982)
Posted: 2020-07-04 03:34 AM . Last Modified: 2024-04-05 03:16 AM
Hi Spezialist ,
Thank you so much ,I totally understood . : )
Best Regards
(CID:128065998)
Ok, thanks for the feedback 😀.
(CID:128066010)
Dear Chu Li Wei,
Have you been able to solve your issue or not?
With respect.
(CID:128062159)
Posted: 2020-07-04 03:34 AM . Last Modified: 2023-10-22 02:26 AM
