Posted: β2020-07-03 02:15 AM . Last Modified: β2024-04-09 12:21 AM
Hi I need to explain to my customer for about NBRK0450
How many AP9520T/TH can connect by A-Link with NBRK0450 ?
(CID:105471917)
Hello Tavorn,
As per the documentation below, you can add up to 8 of the AP9520T/TH to that appliance.
http://www.apcmedia.com/salestools/LSCZ-7BUKZ9/LSCZ-7BUKZ9_R6_EN.pdf?sdirect=true
John T
(CID:105471941)
Posted: β2020-07-03 02:15 AM . Last Modified: β2024-04-09 12:20 AM
Hi Tavorn,
Pl use only Cat 5 or Cat 5e cable for connection as the result is not satisfactory with Cat6. Also Pl do not forget to change DIP switch configuration as per manual.
Manish Modi
(CID:105472067)
Posted: β2020-07-03 02:16 AM . Last Modified: β2023-10-31 11:03 PM
