Firewall rules for Netbotz, DCE & DCO
  • EcoStruxure IT forum
  • Firewall rules for Netbotz, DCE & DCO
126
65
Back to EcoStruxure IT forum
Posted: ‎2020-07-03 10:20 PM . Last Modified: ‎2024-04-07 11:07 PM
1044
Hi all,
I'm in the process of moving my DCE & DCO servers into a firewall zone to allow future struxureon access. To do this I need to know exactly what incoming and outgoing ports are required for Netbotz, DCE & DCO?
https://dcimsupport.apc.com/display/public/UADCE725/StruxureWare+Data+Center+Expert+Security
The link above details which protocols and ports are needed however if does not tell me if the ports are incoming, outgoing or bidirectional.
Thanks in advance.
Scott
(CID:124521050)
  • Data Center Operation
  • NetBotz
1043
Hi Scott,
The FAQs for NetBotz and DCE may help you.
http://www.apc.com/ag/en/faqs/FA158322/
http://www.apc.com/ag/en/faqs/FA158328/
For most of the ports, they would be bi-directional. I will let someone else clarify for DCO.
Regards
(CID:124521112)
Replies 6
1044
Hi Scott,
Regards
(CID:124521112)
Reposting John's previous comment below. DCO firewall rules are here:
StruxureWare Data Center Operation Network Firewall Port Details
(CID:124521205)
DCO incoming and outgoing ports are here.
(CID:124521143)
Thank you both.
Are you able to help me a use case (example) for the following ports?
  • 139 SMB
  • 111 NFS mount
  • 2049 - NFS to NAS / SAN
  • 445 CIFS to NAS
I don't believe my environment requires these ports to be opened. My environment is a physical DCE and virtual DCO.
Scott
(CID:124522856)
Hi Scott,
Typically these ports would need to be opened if you were using external network storage for DCE or DCO. This could be on a Windows or NFS Share or a NAS/SAN drive.
Hope this helps to clarify.
(CID:124522858)
Posted: ‎2020-07-03 10:20 PM . Last Modified: ‎2023-10-22 02:05 AM
