Posted: β2020-07-03 12:21 PM . Last Modified: β2024-04-08 01:58 AM
There was made DCO v7.5.0 upgrade to DCO v8.0.2.
And the issue appeared in Energy Efficiency module:
When pressing "Evaluate Energy System", it shows PUE=32.08(!) now. Also, there should be only one folder with scripts in the desktop client "EE Configuration" tab "Scripts" - now there are 37(!) folders (all the same).
Have you already come around with such issue and can you, please, suggest the possibilities to fix it?
(CID:110793018)
Hi Janis,
The fix for the duplicate entries are included in DCO 8.0.3, which have been released sometime ago.
Please see the following page, under the section "Fixed issues -> DCO Energy Efficiency: Scripted sensors duplication":
What is new in StruxureWare Data Center Operation 8.1
Issue basically is the way client displays the scripts - the database itself dose not contain duplication! The PUE calculations would not be affected as the duplicates only can occur in the client user interface (and not in the database).
I can have a look at your 7.5 backup and see how it goes when it is restored on the latest version of DCO (currently DCO 8.0.3), then I would also need the "evaluated" values for each script (to be able to run the PUE calculations). Please let me know if I should send you an invite to my =S= box folder, thanks.
Kind regards
(CID:110793246)
Posted: β2020-07-03 12:22 PM . Last Modified: β2024-04-08 01:58 AM
Hello Jef,
Thank you for the answer. Can you please PM me, to discuss some further questions?
JΔnis
(CID:110793287)
Hi Janis,
I have send you an invite to my box folder moment ago, so the following data can be share with me: copy of the DCO backup file(s), and evaluated values for each script (in the EE configuration) plus screen captures/descriptions illustrating the issue, thanks.
Kind regards
(CID:110794619)
Posted: β2020-07-03 12:22 PM . Last Modified: β2023-10-22 02:01 AM
