Posted: 2020-07-02 10:18 AM . Last Modified: 2024-04-10 12:56 AM
Hello everybody.
I am configuring some Netbotz appliances like 570 for example and sometimes when i put the informations about email server , i try to do the "send test email" but it shows like : unable to send test email. I did the whole steps that the Netbotz guide suggests I reached good results but last time, i put all the informations and the same message appears.All informations were correct but it didn´t work. Probably the Netbotz is not accessing the mail server , or there´s some SSL problem , i don´t know.
Does anybody knows if there are ways to prove that the Netbotz is sending the emails but the problem it´s on mail server ?
Thanks .
(CID:93914506)
Hi Luis,
Just an added comment to Nathans's answer. Make sure you have added the FQDN for the hostname in the "Network Interfaces" app under Advanced View. I have seen problems sending mail due to this.
Breda
(CID:93914522)
Hi Luis,
Here are a few suggestions for troubleshooting:
(CID:93914508)
Thank you so much !!!
(CID:93915180)
Hi Luis,
Breda
(CID:93914522)
(CID:93915181)
Posted: 2020-07-02 10:18 AM . Last Modified: 2023-10-31 10:56 PM
