EcoStruxure IT GW: voltages sensor names not correct for Smart-UPS VT
Showing results forΒ
Did you mean:Β
  • EcoStruxure IT forum
  • EcoStruxure IT GW: voltages sensor names not correct for Smart-UPS VT
124
110
64
Back to EcoStruxure IT forum
Posted: β€Ž2020-07-04 05:55 PM . Last Modified: β€Ž2024-04-04 11:45 PM
1526
Hi all!
After updating the EcoStruxure IT Gateway software to version 1.3.3.2, I found that the AC voltages sensor names for the three-phase models of Smart-UPS VT (NMC2 firmware is v6.5.6) are not correct:
I.e., the names of AC voltages sensors should be line-neutral, and not line-line.
Very thanks for the support.
(CID:131963501)
  • DDF
  • IT Expert
  • bug
Posted: β€Ž2020-07-04 05:56 PM . Last Modified: β€Ž2024-04-04 11:45 PM
Hi Support team,
I am glad to inform you, that the above-mentioned bug was successfully fixed in the latest firmware v.6.6.4 for NMC2 when using the latest version of the free software EcoStruxure IT Gateway.
Good job πŸ˜€.
(CID:134686235)
Replies 13
Dear Schneider Electric colleagues can confirm above mentioned bug or not?
Will this bug be fixed in the future?
(CID:131966486)
Hi support team,
I'm noting that, unfortunately, the above bug is still not fixed in the new version of the software EcoStruxure IT Gateway 1.3.4.6.
(CID:132647491)
1527
This does not appear to be a bug.  Looking at the sensor values in your screenshot, all the device's "Phase Orientation" sensors are set to "Phase to Phase", the Gateway software uses this information to set the labels for the Input and Output Voltages to "Line-Line".
(CID:132658351)
Dear Ralph Berrett,
This does not appear to be a bug...
This is the bug, because if sensor Output Phase Orientation = Phase to Phase (3P) is visible from my screenshot, then sensors Phase to Phase voltages should be 400V, but not 230V. Since we have 230V - this is Phase to Neutral voltages. I hope you understand me correctly.
With respect.
(CID:132658358)
1527
Hello spezialist.
Can you get screenshots from the device UI? What is it reporting?
Can you do an SNMP Walk on the Smart-UPS VT and send me the results? I think you have my email address already. I can get it to you again if needed.
We need to narrow down where the breakdown is.
Thank you kindly,
Jason
(CID:132658370)
Dear Jason Dutra,
The my screenshot clearly shows that for the UPS Smart-UPS VT 40kVA Phase to Neutral voltages is 230V:
Firmware of my UPS Smart-UPS VT 40kVA:
Can you do an SNMP Walk on the Smart-UPS VT and send me the results?..
I think that this is not necessary, since my UPS – is a native Schneider Electric UPS with NMC2 with the latest firmware 6.5.6:
In addition, for this UPS in DCE-server 7.5.0, all voltages are correctly displayed.
But if you really need snmpwalk-file for Smart-UPS VT 40kVA with NMC2 AP9631, then I can do it only on Wednesday, June 20.
With respect.
(CID:132658372)
Hello spezialist,
In an effort to find a device to test against here we have discovered a bug logged for this very issue. This bug is in the NMC2 firmware used by the Smart-UPS VT units. It appears it was logged fairly recently and has not been addressed yet. I have updated the internal ticket with a link to this forum post.
Hopefully this will be fixed within a future NMC firmware update.
Kind reagrds,
Jason
(CID:132658379)
Dear Jason Dutra,
Thanks for the good feedback. I also hope that soon this bug will be fixed and I will be able to confirm this successfully.
With respect.
(CID:132658381)
Dear Jason Dutra,
Unfortunately, the above bug has not been fixed in the new version of the EcoStruxure IT Gateway 1.4.0.68 software.
With respect.
(CID:134027119)
1529
Hello spezialist,
As I stated in my last reply "This bug is in the NMC2 firmware used by the Smart-UPS VT units."
This is not an issue that can be fixed with a Gateway update. I have logged a bug against the UPS firmware and it looks like it will be addressed in an upcoming UPS firmware. I do not have a release date for the UPS firmware.
Kind reagrds,
Jason
(CID:134027469)
Dear Jason Dutra,
Ok, I hope that soon it will be fixed.
(CID:134027500)
Hi Support team,
Good job πŸ˜€.
(CID:134686235)
Posted: β€Ž2020-07-04 05:57 PM . Last Modified: β€Ž2023-10-22 01:59 AM
This is a heading
