Posted: 2020-07-06 12:18 AM . Last Modified: 2024-04-02 11:37 PM
Our customer would like to integrate Easy UPS 3S into DCE via SNMP. Is there a DDF file for download? In DDF catalog I can find only for modbus
(CID:152571153)
Dear Evgeny,
Please find the attached Easy UPS 3S SNMP card DCE DDF file. ppc_upsmate.zip
Easy UPS 3S SNMP card uses ppc DDF file.
https://ddf.ecostruxureit.com/
Note: If you are using the latest DA807 SNMP card in your Easy UPS 3S, then please ensure to enable SNMP version 3 on the SNMP card before discovering it in DCE software. SNMP version 1 is not supported in DA807 type card.
(CID:152571166)
Dear Evgeny,
(CID:152571166)
Dear Balaraman! It is clear. Thanks for very fast reply!
(CID:152571174)
Posted: 2020-07-06 12:19 AM . Last Modified: 2024-04-02 11:37 PM
Hi Balaraman Jagadeesan, I have tried to discover two easy UPS 3S with DA807 SNMP card.
I am able to discover the UPS's only if using "None" for auth and privacy. Using MD5, SHA, DES or AES gives nothing (a SNMP device is seen but show as not communicating and see no sensor). The strange thing is that if I use the SNMP device walk from DCE web interface, I am able to retrieve OIDs data using auth and privacy settings. Any idea of could be wrong here ? Could it be a DDF issue ? I am using DCE 7.7.1.
(CID:154404772)
Hi Francois,
I want to know if the attached DDF of Easy UPS 3S SNMP card was added already? The DDF is not preloaded in DCE for this UPS SNMP card.
I could discover the Easy UPS 3S SNMP card DA807 in DCE and EcoStruxure IT gateway successfully.
I configured the following SNMP version as an example
User name: admin
Auth. Protocol: MD5
Privacy Protocol: DES
Password: 12345678
(CID:154404942)
The DDF PPC UPSMate UPS version 4 is loaded.
I basically did what is decribed in your screen shots (with different user names and password).
The stranger is that we have two UPS and we tried the following yesterday :
I will try today an upgrade to version 7.8.
For now, I have dicovered the two UPS with no auth and privacy passwords
Rgds
F
(CID:154405042)
Hi Balaraman Jagadeesan, upgrade to 7.8 has fixed the issue. UPS can now be discovered using passwords for authentication and privacy.
Thanks for your support,
F
(CID:154405321)
Posted: 2020-07-06 12:19 AM . Last Modified: 2023-10-22 01:58 AM
