Posted: 2020-07-06 12:16 AM . Last Modified: 2024-04-02 11:38 PM
We want to use DCE as authentication server in ITA.
But get the following error and can't select any username.
What can be the reason?
Eduard
(CID:152571091)
Posted: 2020-07-06 12:17 AM . Last Modified: 2024-04-02 11:38 PM
Dear Everard Eduard,
From your question:
Where did you get such information? As far as I know, the DCE-server has never been and cannot be an authentication server.
With respect.
(CID:152571119)
Posted: 2020-07-06 12:17 AM . Last Modified: 2024-04-02 11:37 PM
Stange answer? DCE is even listed in the drop down menu.
Eduard
(CID:152571141)
I am also interested to know: and how does it work?..
(CID:152571162)
Hi Eduard,
What is the version of your DCE?
It is supported to integrate DCE as authentication server in DCO/ITA.
However, it seems we have software bug that needs to be fixed. I have verified this moment ago with ITA 9.0.4 & DCE 7.7.1, getting similar error when trying to add user that should have been authenticated via DCE.
I have logged a bug report for this.
Kind regards
(CID:152571185)
Dear Jef Faridi,
From your answer:
Tell me please, somewhere in the documentation on DCE it is said about such a possibility?
The DCIM community will be grateful if you indicate where is located the detailed description of this possibility (in the documentation or on the DCIM portal).
Very thanks for the support.
(CID:152571206)
There is a mention to this functionality in the DCO documentation here: https://sxwhelpcenter.ecostruxureit.com/display/UADCO8x/Configuring+authentication+servers+used+for+...
(CID:152571231)
Greg Sterling, thanks for the info.
If possible, briefly tell us which authentication mechanism is used in this case (via DCE)?
In addition, I drew attention to this:
Indirect AD authentication (via DCE) is not recommended.
Can you comment please?
(CID:152571236)
Hi Jef,
I'm running the same version as you:
Eduard
(CID:152571246)
spezialist, this mechanism was implemented in early DCO versions. At that moment DCO had no AD authentication feature, but it was in DCE. So you create remote user in DCE which authenticated via AD. And after that create user in DCO which autenticated in DCE.
And when you try to login into DCO, it call DCE, which call AD and in the end of the journey user is athenticated by AD 🙂
(CID:153092177)
Hi all,
Many thanks for the info Eduard. Issue might basically be related to the latest improvement in DCE itself, however as mentioned I have logged an investigation/enhancement case for this.
And to clarify:
In ITA (or DCO) when configuring authentication servers, the supported types are:
Active Directory
Data Center Expert
LDAP
This type of authentication has been (and still is) supported since early DCO versions.
The scenario Valentin you are describing may or may not work, but that is not supported in ITA (or DCO). User(s) must be local to DCE, when DCE is being used as authentication server.
Kind regards
(CID:153092189)
Posted: 2020-07-06 12:18 AM . Last Modified: 2024-04-02 11:37 PM
Valentin Kozlov and Jef Faridi,
Many thanks for the useful information.
It seems to me, that this detailed information should be published on the DCIM portal in both the DCO and DCE support sections.
With respect.
(CID:153092195)
This feature is being used in DCO/ITA, for more info please see the following page:
Kind regards
(CID:153092198)
Jef Faridi,
I know this and this is good, but it does not say about the restriction that you wrote about:
I think this is an important nuance.
With respect.
(CID:153092201)
The documentation (in the above mentioned web page) says "Indirect AD authentication (via DCE) is not recommended."
But, thanks for the suggestion, will add additional note to make it more clear.
Kind regards
(CID:153092207)
Ok, many thanks for the clarification.
(CID:153092213)
Posted: 2020-07-06 12:18 AM . Last Modified: 2023-10-22 02:52 AM
