How to change the sequence of a breaker panel?
  • How to change the sequence of a breaker panel?
129
72
Posted: ‎2020-07-06 12:19 AM . Last Modified: ‎2024-04-02 11:36 PM
1152
I can no longer create a double rail breaker panel.  Has this recently been changed?  Please advise how I can go about in creating a double rail breaker panel.
(CID:152571210)
  • Data Center Operation
Replies 5
I do not think this capability has changed. Can you specify which version of dco or ita your using?
Regards
Greg Sterling
(CID:152571221)
So when you place a PDU on the floor, then from the breaker panel view add a breaker panel you do not see this option? The below picture is from DCO 8.3
(CID:152571225)
1152
Hello Greg,
My bad....The layout portion wasn't showing....until I extended the window.  For some reason, the minimized window now blocks the layout section(it didn't before) and there is no scroll option so I did not realize that it could be hiding until I maximized the window.  Thanks for your help!
(CID:152571249)
Posted: ‎2020-07-06 12:20 AM . Last Modified: ‎2024-04-02 11:36 PM
No problem at all, glad you have that figured out.
Regards
Greg Sterling
(CID:152571252)
Posted: ‎2020-07-06 12:20 AM . Last Modified: ‎2023-10-22 02:27 AM
