Posted: ‎2020-07-03 12:36 AM . Last Modified: ‎2024-04-09 12:53 AM
Hi Community,
We have ETL Setup exe which is for DCO 7.3.0,however we are using DCO 7.5.0 and PME 7.2 currently, so we need ETL setup file for those DCO and PME. Could you please let me know how can i find it?
Kerem
(CID:105467345)
Hi Karem, at DCO end the configuration is setting up ETL database and the process is defined at Configuring StruxureWare Power Monitoring Expert integration, which remains the same with DCO 7.5.
If you are looking for ETL setup file for PME ETL, please refer to SxW PME documentation. You can also post any specific queries to PME community https://community.se.com/community/power-management-community
Hope this helps,
Ajay Nagar
(CID:105467552)
Hi Ajay, I asked this question in PME community. https://community.se.com/message/82497#82497 kerem.yilmaz
(CID:105467570)
I hope you get an answer there. As far as I remember, the ETL installer is part of PME install itself, I will let experts on the exchange community speak for sure though.
(CID:105467573)
Posted: ‎2020-07-03 12:36 AM . Last Modified: ‎2023-10-31 10:57 PM
