Posted: 2020-07-03 09:31 AM . Last Modified: 2024-04-08 03:30 AM
Hi Team ,
Our customer used Wiegand HID card which spec is 35bit 13.56MHz ,I'd like to know if this card can
support our APC HID rack access AP9361 ? I also check user manual but not sure it can work.
Kindly check it and would be appreciated .
Best Regards
(CID:110011387)
HI!
AP 9631 works with HID cards and have antenna tuned on 125 KHz, So it's incompatible with 13.56 MHz cards.
As option you could look at Netbotz 250 with NBACS1356 handles. It supports 13.56 MIFARE cards and will support iCLASS cards soon.
(CID:110011440)
Posted: 2020-07-03 09:31 AM . Last Modified: 2023-10-22 01:56 AM
