Posted: 2020-07-03 09:31 AM . Last Modified: 2024-04-08 03:30 AM
My DCO installs fine, but when I go to run it the program always hangs on the "Loading Base Model Services" step. After hanging for a couple minutes it will give me the error "An exception occurred - the application will be shut down. Unable to subscribe for events. Cannot find a server to failover onto. There are too many failovers." I can startup just fine on someone else's machine with my account. There are other users with the same firewall settings as my machine, and they all can startup fine. I have tried running DCO with full privileges as well as uninstalling and reinstalling.
I get these events from my event manager and the application's error log:
Information:
Response: Not available
Cab Id: 0
Problem signature:
P1: StruxureWare Data Center Operation.exe
P2: 0.0.0.0
P3: 4d87ac10
P4: 82f0
P5: 67247104
P6:
P7:
P8:
P9:
P10:
\\?\C:\Users\benne244\AppData\Local\Temp\WER22B9.tmp.version.xml
\\?\C:\Users\benne244\AppData\Local\Temp\WER22CA.tmp.xml
\\?\C:\ProgramData\Microsoft\Windows\WER\Temp\WER22EB.tmp.WERInternalMetadata.xml
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Critical_StruxureWare Dat_55ffb3da89228ad134579d692d2828211b51e0_e1bc2d0f_cab_be7122e8\memory.hdmp
C:\ProgramData\Microsoft\Windows\WER\ReportQueue\Critical_StruxureWare Dat_55ffb3da89228ad134579d692d2828211b51e0_e1bc2d0f_cab_be7122e8\triagedump.dmp
These files may be available here:
Analysis symbol:
Rechecking for solution: 0
Report Id: 813b5fb9-cc63-11e6-87cf-64006a4fc446
Report Status: 4
Hashed bucket:
Error:
The program StruxureWare Data Center Operation.exe version 0.0.0.0 stopped interacting with Windows and was closed. To see if more information about the problem is available, check the problem history in the Security and Maintenance control panel.
Process ID: 1a94
Start Time: 01d260701632241f
Termination Time: 4294967295
Application Path: C:\Program Files\StruxureWare Data Center Operation 7.4.0\application\StruxureWare Data Center Operation.exe
Faulting package full name:
Faulting package-relative application ID:
Information:
Fault bucket 129311757982, type 5
Event Name: AppHangB1
Cab Id: 0
Problem signature:
P2: 0.0.0.0
P3: 4d87ac10
P4: 82f0
P5: 67247104
P6:
P7:
P8:
P9:
P10:
C:\ProgramData\Microsoft\Windows\WER\ReportArchive\Critical_StruxureWare Dat_55ffb3da89228ad134579d692d2828211b51e0_e1bc2d0f_823551a9
Analysis symbol:
Report Status: 0
Hashed bucket: 223ccee65985585098775a696b87f5be
And this is the DCO error log:
!SESSION 2016-12-14 09:08:59.570 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_45
java.vendor=Sun Microsystems Inc.
BootLoader constants: OS=win32, ARCH=x86_64, WS=win32, NL=en_US
Framework arguments: -application com.apc.isxo.client.bootstrap.application
Command-line arguments: -os win32 -ws win32 -arch x86_64 -application com.apc.isxo.client.bootstrap.application -clean
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:09:01.230
!MESSAGE Downloading to: /C:/Program Files/StruxureWare Data Center Operation 7.4.0/application/dropins
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:09:32.466
!MESSAGE Logging in to dco.oc.unlv.edu:443
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:10:54.418
!MESSAGE Time to download: 78s
!ENTRY com.apc.sma.client 1 0 2016-12-14 09:11:14.486
!MESSAGE JVM args: [-Xms256M, -Xmx768M, -XX:+UseConcMarkSweepGC, -XX:+CMSIncrementalMode, -XX:+CMSIncrementalPacing, -XX:MaxPermSize=256M, -XX:+HeapDumpOnOutOfMemoryError, -Dfile.encoding=utf-8, -DbuildType=Release, -Dosgi.bundlefile.limit=0, -DsyncProduct=OPERATIONS, -Dosgi.nls.warnings=ignore]
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:11:14.530
!ENTRY org.lwjgl 1 1 2016-12-14 09:11:15.917
!MESSAGE Set org.lwjgl.librarypath to C:\Program Files\StruxureWare Data Center Operation 7.4.0\application\plugins\org.lwjgl_2.8.5.v20121104-2022\native\windows
!ENTRY com.apc.dcoverview 4 0 2016-12-14 09:16:05.477
!MESSAGE Error creating startup input (loading)
!STACK 0
com.apc.dsmf.client.webservices.event.QueueRemoteEventException: Unable to subscribe for events. Cannot find a server to failover onto. There are too many failovers.
at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueue(QueueRemoteEventServiceImpl.java:265)
at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:197)
at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueueWithRetry(QueueRemoteEventServiceImpl.java:203)
at com.apc.dsmf.client.webservices.JMSServiceFactory.createRemoteEventService(JMSServiceFactory.java:25)
at com.apc.dcoverview.services.impl.RemoteServiceProvider.getEventService(RemoteServiceProvider.java:22)
at com.apc.dcoverview.services.ServiceFactory.getEventService(ServiceFactory.java:51)
at com.apc.dcoverview.DefaultServices.registerServices(DefaultServices.java:161)
at com.apc.dcoverview.DefaultServices.loadModel(DefaultServices.java:94)
at com.apc.config.workbench.ServiceRegistryReader.loadForegroundServices(ServiceRegistryReader.java:222)
at com.apc.config.workbench.ServiceRegistryReader.loadServices(ServiceRegistryReader.java:80)
at com.apc.sma.client.ApplicationWorkbenchAdvisor$2.run(ApplicationWorkbenchAdvisor.java:200)
at com.apc.config.workbench.threads.impl.wrappers.RunnableWrapper.run(RunnableWrapper.java:18)
at java.util.concurrent.Executors$RunnableAdapter.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(Unknown Source)
at java.util.concurrent.FutureTask.run(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.access$301(Unknown Source)
at java.util.concurrent.ScheduledThreadPoolExecutor$ScheduledFutureTask.run(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(Unknown Source)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
at com.apc.config.workbench.threads.impl.ModelModificationThread.run(ModelModificationThread.java:10)
Caused by: javax.jms.JMSException: Maximum number of failover attempts exceeded. Cannot find a server to failover onto.
at org.jboss.jms.client.container.ClusteringAspect.handleCreateConnectionDelegate(ClusteringAspect.java:234)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Unknown Source)
at org.jboss.aop.advice.PerInstanceAdvice.invoke(PerInstanceAdvice.java:122)
at org.jboss.aop.joinpoint.MethodInvocation.invokeNext(MethodInvocation.java:102)
at org.jboss.jms.client.delegate.ClientClusteredConnectionFactoryDelegate.createConnectionDelegate(ClientClusteredConnectionFactoryDelegate.java)
at org.jboss.jms.client.JBossConnectionFactory.createConnectionInternal(JBossConnectionFactory.java:205)
at org.jboss.jms.client.JBossConnectionFactory.createTopicConnection(JBossConnectionFactory.java:115)
at org.jboss.jms.client.JBossConnectionFactory.createTopicConnection(JBossConnectionFactory.java:109)
at com.apc.dsmf.client.webservices.event.QueueRemoteEventServiceImpl.initializeQueue(QueueRemoteEventServiceImpl.java:220)
... 30 more
!SESSION 2016-12-14 09:31:45.173 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:31:46.711
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:32:01.035
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:32:18.679
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:32:19.132
!MESSAGE Time to download: 0s
!ENTRY com.apc.sma.client 1 0 2016-12-14 09:32:39.339
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:32:39.349
!ENTRY org.lwjgl 1 1 2016-12-14 09:32:40.215
!ENTRY com.apc.dcoverview 4 0 2016-12-14 09:37:27.205
!STACK 0
... 30 more
!SESSION 2016-12-14 09:38:06.187 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:38:07.468
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:38:30.098
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:39:06.374
!MESSAGE Time to download: 35s
!ENTRY com.apc.sma.client 1 0 2016-12-14 09:39:11.086
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 09:39:11.097
!ENTRY org.lwjgl 1 1 2016-12-14 09:39:11.757
!ENTRY com.apc.dcoverview 4 0 2016-12-14 09:43:59.338
!STACK 0
... 30 more
!SESSION 2016-12-14 11:02:43.016 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 11:02:44.383
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 11:03:24.950
!MESSAGE Logging in to 10.96.68.244:443
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 11:03:26.073
!ENTRY com.apc.sma.client 1 0 2016-12-14 11:04:14.317
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 11:04:14.374
!ENTRY org.lwjgl 1 1 2016-12-14 11:04:15.904
!ENTRY com.apc.dcoverview 4 0 2016-12-14 11:09:03.932
!STACK 0
... 30 more
!SESSION 2016-12-14 13:00:34.612 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 13:00:36.110
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 13:00:54.048
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 13:00:55.544
!ENTRY com.apc.sma.client 1 0 2016-12-14 13:01:36.681
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 13:01:36.744
!ENTRY org.lwjgl 1 1 2016-12-14 13:01:42.004
!ENTRY com.apc.dcoverview 4 0 2016-12-14 13:06:52.192
!STACK 0
... 30 more
!SESSION 2016-12-14 16:07:54.199 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 16:07:55.969
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 16:08:37.488
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 16:08:38.826
!ENTRY com.apc.sma.client 1 0 2016-12-14 16:09:26.294
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-14 16:09:26.335
!ENTRY org.lwjgl 1 1 2016-12-14 16:09:27.397
!ENTRY com.apc.dcoverview 4 0 2016-12-14 16:14:14.658
!STACK 0
... 30 more
!SESSION 2016-12-15 07:59:37.509 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 07:59:38.922
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 08:00:03.452
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 08:00:04.734
!ENTRY com.apc.sma.client 1 0 2016-12-15 08:00:49.141
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 08:00:49.196
!ENTRY org.lwjgl 1 1 2016-12-15 08:00:51.274
!SESSION 2016-12-15 08:05:10.526 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 08:05:11.875
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 08:05:20.157
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 08:05:20.790
!ENTRY com.apc.sma.client 1 0 2016-12-15 08:05:39.662
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 08:05:39.673
!ENTRY org.lwjgl 1 1 2016-12-15 08:05:40.387
!ENTRY com.apc.dcoverview 4 0 2016-12-15 08:10:27.134
!STACK 0
... 30 more
!SESSION 2016-12-15 09:00:54.987 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 09:00:57.054
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 09:01:58.096
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 09:02:07.049
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 09:02:07.769
!ENTRY com.apc.sma.client 1 0 2016-12-15 09:02:47.492
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-15 09:02:47.555
!ENTRY org.lwjgl 1 1 2016-12-15 09:02:48.845
!ENTRY com.apc.dcoverview 4 0 2016-12-15 09:07:36.877
!STACK 0
... 30 more
!SESSION 2016-12-16 12:54:42.231 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 12:54:43.620
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 14:56:30.158
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 14:56:32.102
!ENTRY com.apc.sma.client 1 0 2016-12-16 14:56:49.419
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 14:56:49.489
!ENTRY org.lwjgl 1 1 2016-12-16 14:56:51.197
!SESSION 2016-12-16 15:01:29.426 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 15:01:30.723
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 15:01:49.248
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 15:02:06.616
!MESSAGE Time to download: 16s
!ENTRY com.apc.sma.client 1 0 2016-12-16 15:02:29.511
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 15:02:29.789
!ENTRY org.lwjgl 1 1 2016-12-16 15:02:30.383
!ENTRY com.apc.dcoverview 4 0 2016-12-16 15:07:17.257
!STACK 0
... 30 more
!SESSION 2016-12-16 16:55:03.162 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 16:55:04.456
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 16:55:20.553
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 16:55:21.468
!ENTRY com.apc.sma.client 1 0 2016-12-16 16:55:56.523
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 16:55:56.590
!ENTRY org.lwjgl 1 1 2016-12-16 16:55:58.190
!SESSION 2016-12-16 16:57:03.029 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2016-12-16 16:57:03.568
!MESSAGE The -clean (osgi.clean) option was not successful. Unable to clean the storage area: C:\Users\benne244\.isxo\7.4.0-30794-3436c\Operations\org.eclipse.osgi
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 16:57:04.329
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 16:57:15.777
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 16:57:16.338
!ENTRY com.apc.sma.client 1 0 2016-12-16 16:57:19.349
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 16:57:19.363
!ENTRY org.lwjgl 1 1 2016-12-16 16:57:20.007
!SESSION 2016-12-16 17:01:13.510 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2016-12-16 17:01:13.915
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 17:01:14.857
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 17:01:32.416
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 17:01:33.248
!ENTRY com.apc.sma.client 1 0 2016-12-16 17:01:35.330
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-16 17:01:35.343
!ENTRY org.lwjgl 1 1 2016-12-16 17:01:35.856
!ENTRY com.apc.dcoverview 4 0 2016-12-16 17:02:06.490
!STACK 0
... 30 more
!SESSION 2016-12-27 10:34:40.844 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:34:41.709
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:34:48.833
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:34:50.314
!ENTRY com.apc.sma.client 1 0 2016-12-27 10:35:02.767
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:35:02.843
!ENTRY org.lwjgl 1 1 2016-12-27 10:35:04.099
!SESSION 2016-12-27 10:36:07.328 -----------------------------------------------
!ENTRY org.eclipse.osgi 4 0 2016-12-27 10:36:07.867
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:36:08.601
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:36:19.278
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:36:19.870
!ENTRY com.apc.sma.client 1 0 2016-12-27 10:36:22.516
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:36:22.532
!ENTRY org.lwjgl 1 1 2016-12-27 10:36:23.305
!SESSION 2016-12-27 10:37:45.380 -----------------------------------------------
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:37:46.352
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:37:54.254
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:37:54.846
!ENTRY com.apc.sma.client 1 0 2016-12-27 10:37:57.523
!ENTRY com.apc.isxo.client.bootstrap 1 0 2016-12-27 10:37:57.535
!ENTRY org.lwjgl 1 1 2016-12-27 10:37:58.119
!ENTRY com.apc.dcoverview 4 0 2016-12-27 10:42:44.831
!STACK 0
... 30 more
(CID:110011557)
Posted: 2020-07-03 09:32 AM . Last Modified: 2024-04-08 03:30 AM
It seems to be network related, eg. DCO-client routing issue between your workstation and DCO server. Even though you might be on the same "network" as other operating clients, your workstation might be using a different route, and/or perhaps running antivirus (with firewall) that might be interfering with the communication.
By the way, I understand you are running one of the earlier versions of DCO (7.4), it is highly recommended to upgrade/move the product to the latest version (currently DCO 8.0.2). You might want to give it a try (eg. fresh installation of 8.x and then restoring the latest 7.4 backup).
DCO 8.x is really great and contains also huge improvements for the client-server communication.
Kind regards
(CID:110011755)
Posted: 2020-07-03 09:32 AM . Last Modified: 2023-10-22 01:46 AM
