Posted: β2020-07-03 05:03 PM . Last Modified: β2024-04-08 12:20 AM
I'm developing a integration via ETL to associate information from a CMDB to the DCO.
The import and the modify of the CI works well, but when I try to delete an element via the ETL, changing the state_flag to "deleted" in the configuration_item table, nothing happens in the DCO and the association remainds.
ΒΏAny idea about that what's happening?
regards.
(CID:120133529)
Hi Carlos
It's interesting that "new" and "changed" work for you but "deleted" doesn't.
I assume you are using lower case as shown here ETL Import Database rather than what the doco says Keeping Track of Information State. Upper case has never worked for me. I also assume you've been using the "state_last_updated" column.
Are you checking that the state_flag = "synced" before you set it to delete?
Cheers
Ed
(CID:120133612)
Hi Carlos
Cheers
Ed
(CID:120133612)
Hello ed,
Finally I found the problem, and it was in my pentaho procedure. I wasn't updating correctly the state_flag column when i was trying to delete the CI.
regards.
(CID:120133811)
Posted: β2020-07-03 05:04 PM . Last Modified: β2023-10-22 01:52 AM
